Skip to main content Skip to search Skip to main navigation
Product information "RS485 Bridge - DIY Hörmann MQTT Adapter - ESP32-S3 Dev Board"
This Development board serves as an RS485 bridge between an RS485-capable device and the home network and IoT software solutions such as Home Assistant. Any application in which RS485 IoT is to be made capable can be easily implemented here.
This board was originally developed to be used via OpenSource Software to control a Hörmann garage door drive, this is still the most frequently used application. As a result, the board is optimized for this and is delivered with a current version of the software, in this case the drive will power the board as well. Reprogramming is possible at any time without any problems so that any RS485-related projects can be realized.
When using the board to control a Hörmann garage door, the pre-installed firmware supports the following models:
Series 4:
 SupraMatic E/P/H 4, ProMatic 4, Duramatic, Liftronic 500-2, Liftronic 700-2, Liftronic 800-2, RollMatic 2
Series 3: SupraMatic 3, SupraMatic HT3, LineaMatic, LineaMatic 2, RotaMatic, RotaMatic 2, VersaMatic, Portronic-2 S4000, Portronic-2 D5000
Important: Berner motors and the Hörmann Promatic 3 are NOT useable with this board!
Info: For motors that cannot operate a garage door, only basic functions such as open/close can be guaranteed.
Using it with such a garage door supports Plug & Play, installation only takes a few minutes!
Install instructions are also available in the OpenSource Software repo: Quick Start Guide
There is also a ESPHome based firmware available now: ESPHome guide
Scope of delivery
  • 1x finished and tested circuit board
  • 1x short RJ12 cable
  • 1x E3 to E4 adapter (Only Series 3 variant)
Technical data
  • ESP32-S3 microcontroller
  • NEW! AHT20 Sensor for temperature and humidtiy
  • RS485 module (MAX485 / CD4069)
  • RJ12 socket (power supply/RS485)
  • USB-C (power supply / programming)
  • Voltage supply between 4.5V - 28V
  • 3V3 / Power LED
  • 4 controllable LEDs
  • RJ12 breakout
  • TTL/Serial Breakout
  • 4 expansion ports for external sensors etc.
  • 4 additional IO pins
  • PCB dimensions only 55x55mm
EXP1 - BMP280 Optimized Pinout
21 of 21 reviews
Average rating of 5 out of 5 stars
100%
0%
0%
0%
0%
Leave a review!
Share your experiences with other customers.
2 - 10 of 21 reviews
17 March 2025 15:21
Review with rating of 5 out of 5 stars
Wahnsinn
Bin absolut zufrieden damit! Sehr guter Preis zu einer top Leistung
An USB-C stöppseln, mit WLAN verbinden & MQTT konfigurieren und dann an das Hörmann Garagentor (Series 4) und schon ists in HA integriert.
Einfacher gehts gar nicht mehr, sehr nice!
4 March 2025 06:44
Läuft Plug&Play mit Supramatic 4
Die Inbetriebnahme mit dem Hörmann Antrieb Supramatic 4 war schnell erledigt:
-WLAN Konfiguration über den WLAN-AP
- Konfiguration der MQTT-Daten für HomeAssistant (HA)
- Anschließen der Platine an den Antrieb -> Suchlauf für Bus-Geräte durchführen
Läuft und wird direkt in HA erkannt/ auf dem Dashboard gezeigt -> TOP
Nachträglich einen BMP280 Sensor anschließen war auch möglich, allerdings muss die Firmware dazu geupdatet werden
-> evtl. ist ein Switch (abhängig vom eingesetzten Sensor) in der Custom-Firmware sinnvoll?
Alles in allem eine super Aufwertung für den Garagentor-Antrieb
1 March 2025 16:12
Perfekt um Hörmann Supramatic 4 ins Home Assistant zu bekommen
Habe 2 Geräte im Einsatz um 2 Garagetore von Hörmann Supramatic in mein HomeAssistant zu bekommen. Beide sind seit 2 Jahren am Laufen ohne Probleme. Das Ganze lief auf Anhieb und ist im Gerät von Hörmann integriert und von aussen nicht einsehbar.
Beschreibung war für ein Laien selbsterklärend und das Support hat mir bei Fragen auch schnell geholfen.
20 January 2025 20:08
Funktioniert einwandfrei
Da im Haus alles smart werden sollte, mussten natürlich auch die Garagentore herhalten. Wichtig is nur dass man weiß welche Version man hat.
Die Anleitung ist leicht verständlich (nicht viel anders bei anderen smarthome-Geräten auf dieser Basis)
Bei Fragen an den Support bekommt man sehr schnell eine Antwort und da wird einem geholfen.
Lieferung war auch sehr schnell.
Sollte jemand mit Hörmann-Motoren demnächste auf Home Assistant umsteigen gibts von meiner Seite eine wämste Empfehlung an dieses Produkt. Weiter so und immer wieder gerne :)
11 November 2024 20:14
Perfekter Ersatz für Hörmann IT-WLAN – Vollständig Home Assistant-kompatibel mit herausragendem Support
Ich hatte zuvor das Hörmann IT-WLAN-Modul im Einsatz, um mein Garagentor in HomeKit einzubinden. Für rund 100€ bot das Originalzubehör jedoch nur eingeschränkte Steuerungsfunktionen, war umständlich einzurichten und lässt sich zudem nicht mit Home Assistant verbinden – ein großes Manko.
Der MQTT-Adapter von Tynet dagegen hat mich restlos überzeugt: Nach einfachem Anschließen, Bus-Scan und Konfiguration von WLAN und MQTT-Broker war alles einsatzbereit und Home Assistant-kompatibel. Besonders positiv hervorzuheben ist der Kundenservice: Nachdem ich die Teilöffnungsfunktion vermisste, wurde diese noch am selben Tag per Firmware-Update ergänzt und war direkt über MQTT und Home Assistant verfügbar. Solch flexiblen und schnellen Support bietet Hörmann nicht.
Fazit: Dieser Adapter ist nicht nur eine kostengünstige Alternative, sondern bietet im Vergleich zum Hörmann-Original überlegene Funktionalität, einfache Einrichtung und hervorragenden Support – ideal für alle, die Home Assistant nutzen!
16 October 2024 12:52
wirklich cool und einfach
Ich habe das Gerät gestern bekommen und nach Anleitung eingebaut. Alles funktioniert auf Anhieb - ich bin begeistert.
Der BUS meines Antriebes war bereits belegt; ich hab mir dann eine Weiche geholt um 2 Dinge an den BUS anzuschließen und auch das war nach einen BUS-Scan kein Problem.
Jede Frage wurde mir innerhalb von Minuten beantwortet. Besser geht nicht.
Ich danke herzlich!!
Our feedback: Freut mich das die Option mit dem Y Kabel geklappt hat! Danke für die Bewertung!
12 March 2024 17:12
Klasse Produkt
Ich habe eine Möglichkeit gesucht, meine Supramatic 4 per MQTT in meine Hausautomation einzubinden.
Die Platine kam super schnell und gut verpackt an. Die neueste Firmware war aufgespielt und die Platine ist steckfertig. Die Einbindung ins eigene WLAN ist Dank AP sehr einfach. Daten konfiguriert und nach dem Busscan lieferte die Karte per MQTT meinem Hausautomation alle Daten.
Da die Platine fertige Anschlüsse für Sensoren bereitstellt, sind hier viele individuelle Optionen möglich.
Der Kontakt war vorbildlich. Toller Service
Danke
11 February 2024 21:54
Fantastic
Worked quickly and easily straight our of the box, highly recommended!
7 February 2024 20:16
Funktioniert wie gewünscht
Schneller Versand
Funktionierte auf Anhieb so wie es soll!
Nur den BME280 bekomme ich noch nicht an laufen.
3 January 2024 08:25
Works perfectly on Hormann Supramatic E4
Professional print, works right out of the box. The print can be stored in the compartment inside the enclosure. Just follow the steps on the Github page. Integration with HA by MQTT was easy. Package arrived within a few days without any problems. Thank you.
